Old 25-Nov-2012, 12:41 AM   #1
wbelk7777
Which Antenna Setup Should I Go With?
I’m looking for input on the best antenna solution for my area. I’ve attached a picture of the stations that I want to pickup. The stations that I’m trying to pickup are in the center of the red V that I’ve drawn. The antenna will be mounted about 25ft off the ground. I would like for the antenna to be fixed, so that I don’t have to move it to pick different stations. Please look over the options that I’m considering below. I’m looking for any recommendations and thoughts. Thanks for the help.
Here is my TV Fool Radar Plot Report Link
Option 1:
A combo VHF/UHF antenna like the AntennaCraft HD1850 with a Channel Master CM7777 Titan2 Mast Mounted Pre-Amplifier
AntennaCraft HD1850
Option 2:
Combining a VHF High Band Antenna (like the Antennacraft Y10-7-13) with a UHF Only Antenna (like the Channel Master 4228HD) with a Channel Master CM7777 Titan2 Mast Mounted Pre-Amplifier
Option 3:
I’m open to suggestions. Whether you want to modify the two options above or come up with something completely different, I’d like to hear your ideas.
wbelk7777 is offline   Reply With Quote
