As always , coax that is outside is suspect of being bad , if water get's into the coax , put the coax in the trash.
The best way to find out if coax is bad is disconnect the coax and connect a known to be good coax in it's place.
The Tv antennas at the house do not "broadcast" , the Tv antennas job is to -Receive - the Tv transmission that is broadcast.
Your location has receivable Tv transmissions in All 3 Tv bands of ,
UHF band channels 14 thru 51.
The HD7084P is a ALL channel antenna that is designed to receive ALL the channels , 2 thru 51.
The Tv reception is Very Weak (the signals are not strong) at your location.
I recommend install a BIG ALL Channel Antenna. The Winegard HD7084P antenna.
