Old 23-Nov-2012, 4:45 PM   #5
The HD7698P antenna will be installed in such a manner that the roof or the house is not blocking reception to the , north , south west , south.
Some Strong and Sturdy antenna mounts , tripod antenna mount , eave antenna mount , chimney antenna mount.
In the Gray reception zone , CJMT-DT 40 Omni 2 , CITY-DT 44 City Tv , CFMT-DT 47 Omni 1 , may or may not be received reliably. The situation is a , install the antenna and see what happens situation.
It is best to install antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
And for your reception situation getting the antenna up high is important.
