The religious programing currently carried on real CH-8, WGCT-CD is also carried on real CH-39. That means a UHF only antenna such as the Antennas Direct DB-4e would offer reception of all the signals you mentioned as well as several others. Aim (face) the antenna toward the south.
Outdoor mounting is superior to attic mounting. So if you have trouble in the attic, the DB4e would be relatively easy to move outside if needed. If your attic is a reasonably good receptions site (many attics aren't), you should be able to connect several TVs with no amplifier needed.
Reason: sp.
