Old 21-Nov-2012, 3:35 PM   #4
cnads
Background noise on VHF channels is common due to local power lines and other electrical distribution infrastructure. If it's present, it will wipe out the weak VHF signals from your northwest.
Unfortunately, it would take a spectrum analyzer to 100% identify if this is your reason for the "No reception" of WGAM's channel 8 signal.
If I am able to raise the antenna a bit more so that it is above the power lines (say 6 feet or so above them) and not pointing directly at them, will that get around most of the noise from the powerlines? Or do I need to be very far from them?
Thanks to both you and teleview for the info. I have some PVC pipe that I am going to use to try to raise the antenna as high as I can so that it is still stable and see if that gets me anything.
cnads is offline   Reply With Quote
