Old 21-Nov-2012, 4:05 AM   #2
Install the Y5713 VHF channels 7 thru 13 antenna above the roof in such a manner that reception is not restricted or blocked buy the roof or house to the , north west at 326 , south east at 163 degree magnetic compass direction.
Aim the Y5713 antenna at 326 degree magnetic compass direction.
Install the CM7777 , preamp , power injector , power supply , for the Y5713 antenna , Only.
The VHF Tv transmission/reception is Very Weak Signal Strength at your location. That is why the CM7777 preamplifier is only connected to the Y5713 VHF antenna.
_________________________________________________________________
Install above the roof in such a manner that reception is not restricted or blocked buy the roof or house to the east at 90 degree magnetic compass.
Install a Antennas Direct Clear Stream 2 CS2 UHF channels 14 thru 51 antenna aimed at about 90 degree magnetic compass direction.
The CM7777 ->Will Not<- be connected to the CS2 antenna.
At a location where the CM7777 preamp can be plugged in for power.
A UVSJ = UHF/VHF Separator/Joiner will connected at that location , the UVSJ requires no power , it is the location that is important.
The Y5713 antenna and CM7777 preamp , power injector , power supply will All be connected to/on the VHF input of the UVSJ.
The Separate coax from the CS2 UHF antenna is connected to/on the UHF connection of the UVSJ.
The UHF Tv transmission/reception is Very Strong Signal Strength at your location , it so strong that a preamplifier will be overloaded , so no amplifier is connected to the UHF antenna.
The third connection of the UVSJ is the output that goes to the Tv/Tv's.
For one Tv connected use no splitter.
For 3 Tv's connected use a common simple 3 way splitter.
As for power for the preamp , power injector , power supply. Most attics have a electric power outlet , the coaxes and preamp and UVSJ can all be routed/installed into the attic. And then the coax to the Tv/Tv's can routed as required.
You remember the word ->Location , the location of electric power is what is important. It does not have to be the attic , but does have to be a location where there is electric power.
For a example of what a UVSJ is , type these letters ->uvsj <- in the http://www.solidsignal.com search box.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/Tv's Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.amazon.com , http://www.antennasdirect.com ,
