Old 20-Nov-2012, 4:50 AM   #4
elmo
Wow! I love it! The RF remote receiver antenna gets new life!
The Eagle Aspen is UHF only so you'll lose stations like WTVI which is VHF. You are close to the transmitter tower, and some say that VHF can be tuned when that close, but that antenna just isn't optimal.
I recommended the ANT-751 to someone else earlier, and I think you'll get fine results w/it in this case. You have a lot of good signal coming at you from various directions and the 751 isn't as directional as others. As for the direction, I'm not sure where is best to point it. That may take some adjusting. Likely you could point at the weaker signals from the west, where those transmitters in Gastonia are; channels 3 & 36 broadcast from there. The others would come in on the back side likely since they're much closer.
