Thread: Is it possible?
Old 20-Nov-2012, 4:10 AM   #2
WEUX, real CH-49 is blocked by terrain and the curvature of the earth. If you see it occasionally it will be because the signal happens to bounce of an ionized layer in the upper atmosphere. Reliable reception would require an extreme tower build.
You can experiment with antenna height in TV Fool signal generator to see what might be possible.
