Old 20-Nov-2012, 3:30 AM   #2
elmo
In regards to the HDHR, do you have the older white version or the newer black version. The older has dual inputs which IMO makes it better, as you can attach two different antennas and tune the best from each. You can set priority for each channel/tuner right from WMC. Then it's seamless channel flipping after that. That'd be an option for you possibly since you have signals in all directions. But if you have the newer HDHR with a single coax, your only option to go this route is another HDHR.
Use the HDHR setup/config app to tune, as it'll give you more details vs WMC's bars will.
As for the DIY antenna, I dunno how much you can expect. I built a similar one that's sitting in the attic right now. It's the wire hangers version on a 1x4 screwed down into an old christmas tree stand. It worked pretty well and was fun to build, but wasn't that great compared to some purchased antennas, plus it had nothing for VHF, like WABC for you.
Another antenna joined directly will likely just cause you multipath issues. Plus there's a rule of thumb for distance between antennas.
