Thanks for the response.
To answer your questions:
I did try the antenna outside, at ground level, but the results were no better.
The antenna is only connected to one TV, with no splitter. I used a 50-foot-long cable (brand new), and later connected another 25-foot cable to that, but it didn't seem to affect the reception. The coax is completely separate from the coax used for the cable TV. And yes, I scanned for 'antenna', not 'cable'.
I hadn't considered using an FM trap. I read that those are only needed for amplified antennas, which I don't have. But for just $5, it might be worth a try. I'm very close to Cougar Mountain.
