Old 19-Nov-2012, 5:19 PM   #6
A Simple reception situation.
This my - recommendation. As always you can make your own choices.
I recommend a new single antenna. 1 antenna solution.
For the Boston area Digital Tv stations/channels , above the roof install a Winegard HD7696P antenna aimed at about 212 degree magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
For 1 Tv connected use no splitter , no preamplifier.
For 2 Tv's connected use a common simple 2 way splitter , no preamplifier.
_________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including or own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
