Old 19-Nov-2012, 5:12 PM   #1
cnads
Should I be able to get this?
i'm hoping that someone can help me out as I'm pretty new to this. I guess I'll start with a link to my report:
http://www.tvfool.com/?option=com_wr...cc4938cfa8e368 - I select "Only Digital - Pending applications included" as there is a channel in there that I actually get. (CBAT-DT/CBC on 31).
So here is my situation. I am hoping to get WAGM-TV/CBS on channel 8 but I am wondering if it is a lost cause. It is a long story about how I got to where I'm at lol so I won't get into that. But I picked up this antenna:
http://www.solidsignal.com/pview.asp...u=716079000987
And I got this preamp:
http://www.solidsignal.com/pview.asp...ku=02057207774
and I have 2 of these mast/extensions joined together to make one long one
http://www.walmart.com/ip/RCA-53-Ant...nsion/14554632
I attached the antenna to the side of the house and pointed it at approx. 308 degrees wrt true north. I was just using the compass on my iphone so I figure it is not completely accurate. I don't get any signal. I've fiddled with it a bunch and got nothing. I have attached a pic of my setup as well as what it is pointing to. It is pointing pretty much directly into some power lines so I assume that, if nothing else, those would interfere with the signal. Is that correct? Originally I wanted to put the antenna at the high point of the roof but I went up there and felt like my life was on the line lol so this is about the best I am going to do I think.
On a related note, I first put my antenna in a room on the back of the house facing pointing out a window at roughly 145 degrees. I am able to get CKLT-DT/channel 9 without much trouble and CBAT-DT and CIHF-DT I can get with pretty much any piece of metal. I then planted the antenna on the mast outdoors pointing in the same direction and I can not get either CKLT-DT or CBAT-DT, so I am wondering if I did something wrong. The mast is metal and the antenna is connected with a metal clamp - could that be causing a problem or is that ok? I also attached a pic of the antenna sitting in the room where I can get a better signal then when it is outside that window. Right now that is where it is sitting. If I can't get WAGM-TV then I'd like a better solution on where to put the antenna so I can at least get CKLT-DT and CBAT-DT
This is a pretty long post so thanks for reading through it! I hope someone can give me some advice.
cnads is offline   Reply With Quote
