Old 19-Nov-2012, 1:04 PM   #2
signals unlimited
The antenna and coax in place are not TV and are of no use in your project.
All receivable stations are located at 178 degrees.
Install an Antennacraft HBU55 or a Winegard HD7698p antenna above your roof aimed to 178 degrees magnetic.
No pre amplifier or rotor are needed. If you are connection more than one set or have a coax run longer than 75 feet you can use a Channel Master distribution amplifier 34xx with the proper number of ports to feed your sets.
