Old 19-Nov-2012, 6:40 AM   #2
The ANT751 is a small antenna and as such is not all that directional.
The bigger a antenna is the more directional the antenna becomes.
The ANT751 does have some directional forward direction gain , and also receives very well at the , back , back angles , and front angles. The least amount of reception is on the sides.
I recommend aim the ANT751 antenna at about 183 degree magnetic compass direction. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Improved reception will happen with the antenna installed above the Roof in such a manner the reception is not blocked by the roof or the house in the directions of , north west , south west , south , east.
Here are some common roof top antenna mounts , tripod antenna mount , eave antenna mount , chimney antenna mount , J type antenna mount.
Here are some places to buy antenna mounts and ect. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
___________________________________________
2 Tv antennas that receive different channel bands , as an example , UHF and VHF can be combined with a special coupler named a UVSJ.
However 2 antennas that are alike and aimed in different directions can not be combined , the 2 antennas will cross talk and the reception will be out of phase with 2 alike channel band antennas , the reception Will Be Bad.
The Tv channel bands are ,
UHF band channels 14 thru 51.
The data base is showing both Digital Tv stations/channels ,
CBUT-DT REAL UHF Digital channel 43 , virtual number (2.1) CBC.
CBUFT-DT REAL UHF Digital channel 26 , virtual number (26.1) SRC French Tv.
