Old 19-Nov-2012, 4:33 AM   #1
jdevries
Reception from 2 Channel groups located 120° apart
I currently have an ANT751 installed in my attic and pointing approximately in a WNW (300°) direction. I get all of the following channels (2.1, 6.1, 8.1, 10.1, 17.1, 26.1, 32.1, 42.1). Interestingly, 8.1, 10.1, 17.1, 32.1 & 42.1 are at 320°, 6.1 is at 230° and I presume that 2.1 & 26.1 are at 301°.
1) Isn't the ANT751 relatively directional and why would I be able to get channels that are spread 90° apart?
I'm going to swing my ANT751 around to approximately 260° in hopes of getting also getting 12.1, 24.1 & 28.1 which are located in a 200° direction. If this does not work, I may need two antennas.
2) Is it possible to combine the input from two ANT751 antennas with one pointing at 320° and the other at 200° without using a A/B switch box?
NOTE: I believe that your database is not showing 2.1 (CBUT; CBC English) and 26.1 (CBUFT; CBC French) however, we get do them.
Location information: http://www.tvfool.com/?option=com_wr...cc49611d7acddf
Thanks,
Jim
jdevries is offline   Reply With Quote
