Thank you in advance for any help or suggestions anyone can provide.
I recently purchased a cabin with an existing antenna mounted approx. 30 ft. above the ground.  I am not sure what kind of antenna it is.  The only way to get any reception is to have a booster in line and then the only channel I can get consistently is CBS.  I will sometimes get ABC and PBS.  I would like to be able to get FOX and NBC if possible.  There is some tree coverage inline in all directions.  I will only have 1 TV hooked up with no splitters.  Any suggestions for the best type of antenna and/or manufactures would be greatly appreciated.
Thank you
Travis
http://www.tvfool.com/?option=com_wr...cc494f37435a63
