Old 18-Nov-2012, 5:05 AM   #9
Reverse engineering to a location that is close to your location.
Shows that a antenna height of 100 feet will get you these Digital Tv stations/channels with 1 antenna.
A Channel Master CM4228HD with a KitzTech KT-200 Remote Power amplifier/booster.
Aimed at about 70 degree magnetic compass direction , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
It is possible to find used towers on the internet for not much money.
WKOW REAL UHF Digital channel 26 , virtual number (x) , ABC and Me-Tv and This Tv.
WISC-DT REAL UHF Digital channel 50 , virtual number (3.1-2) , CBS and MyNetwork.
WHA-TV REAL UHF Digital channel 20 , virtual number (21.1-2-3) , PBS.
WMSN-TV REAL UHF Digital channel 49 , virtual number (47.1-2) , FOX and the Country Network.
WMTV REAL UHF Digital channel 19 , virtual number (15.1) , NBC.
And most likely , WBUW-DT REAL UHF Digital channel 32 , virtual number (57.1) , The CW.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com, http://www.kitztech.com , http://www.palcoelectronics.com/pe300.aspx.
_________________________________________________________
For reception at 40 to 60 feet , the closer to 60 feet the better.
At about 70 degree magnetic compass direction ,
WKOW , ABC and Me-Tv and This Tv.
WISC , CBS and MyNetwork.
WHA , PBS.
And at 203 degree magnetic compass direction , with a Winegard YA1713 VHF high band antenna KWWL REAL VHF Digital channel 7 , virtual number (x) , NBC and Me-Tv and This Tv.
Connect the CM4228HD and the YA1713 together with a UVSJ and connect the UVSJ to the KT-200 Remote power amplifier booster.
The KT-200 remote power amplifier booster provides the flexability of installing the booster unit outdoors close to the antenna or indoors.
UVSJ = UHF/VHF Separator/Joiner . Buy the UVSJ at solidsignal buy typing these letters in the solidsignal search box -> uvsj.
The CM4228HD UHF antenna connects to the UHF port of the UVSJ.
The YA1713 connects to the VHF port of the UVSJ.
The KT-200 connects to the third port of the UVSJ.
Here is a 10 foot tripod antenna mount for mounting on the roof , http://www.ronard.com/Tripods%200703/4712.html.
http://www.3starinc.com has push up masts that use guy wires.
