Old 17-Nov-2012, 10:56 PM   #7
amp113
Prior to the HD switch over we used a Channel Master CM 3671 (or equivalent). We were able to get channel 7 and 9 to the southwest. I will get that out and hook up to see what channels I can search out now. We only have one television. If I can get a weak signal will a pre-amp boost it? Coaxial run from antenna to television is approximately 20 to 25 ft. I ran the plot with a 35 ft. which is probably the highest I can get the antenna without a tower. The signal strength doesn't improve much.
amp113 is offline   Reply With Quote
