Old 17-Nov-2012, 3:33 PM   #14
crysto4
Gonna Start Today
Hey folks,
I wanted to thank you for the information you've furnished so far!
I'll be running a cable from where the cable comes to the old FIOS box which right now is used only as a giant splitter for cablevision. I figured I could pull the cable thru the same penetration as the exist. one. I hope it fits! Thats the first test. I have an antenna on the way and will most likely just buy a cheap box as suggested. The higher end digital ones seem to not be to good from reviews I've read. THEN I'll find if this antenna ends in the attic or outside on the roof. I'm not sure which way will be easier right now. I have underground electric and cable so I'd have to drape the line down and run behind gutter, along facia, etc. to get to the ground penetration to the house. I got a bad feeling about the penetration size though...
I'll keep you posted.
Thanks again -
crysto4 is offline   Reply With Quote
