Old 16-Nov-2012, 1:56 AM   #5
I recommend reception of both the , south and north Digital Tv stations/channels.
Install a ANT751 antenna above the roof in such a manner the the roof or house is not blocking reception to the south and north.
Aim the ANT751 antenna at about 0 degree magnetic compass direction , north.
So you say , why aim the antenna north when the main group of Tv stations you are interested in are to the south.
And I say , the south group of Tv stations are strong signal strength.
The north group are weaker signal strength.
The ANT751 antenna does have some forward gain to improve reception to the north , and will also receive very well at the back of the antenna.
So aim the ANT751 at the weaker Tv stations to the north.
And the much stronger Tv stations to the south will be received through the back of the ANT751.
No preamplifier required.
For 2 Tv's connected use a common simple 2 way splitter.
_________________________
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the ANT751 antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
