Old 15-Nov-2012, 3:17 PM   #1
NascarNHIS
Question Antenna help - Boston Area
New to OTA, I just dumped DISH. I setup a cheap set of rabbit ears (RCA ANT112R) and receive a few channels. 2-1 5-1 5-2 62-1 62-1. I then I remembered I have a 30 year old TV antenna (model unknown) mounted about 30 ft. high on my chimney with an old thin twin flat wire 300ohm cable so I connected that with a balun directly to my VISIO XTV553SV flat screen. And did much better. I now get
2-1 WGBH-HD 1080I
2-2 WORLD 480I
4-1 WBZ-TV 1080I
5-1 WCVB 1080I
5-2 METV 480I
25-1 WFXT 720P
38-1 WSBK-TV 1081I breaks up, poor reception
44-1 WGBX-HD 1081I
44-3 CREATE 480I
44-4 KIDS 480I
62-1 WMFP 1080I
62-2 WMFP DT2 480I
Do not need this channel 66-1 wutf-dt = breaks up .
My question is what do I need to do to get
7-1(42) WHDH NBC BOSTON 2Edge = (priority 1 for me)
56 WLVI- CW Cambridge Edge1
68-1 WPBXTV Boston Edge2
38-1 WSBK-TV want to improve quality Edge1 = (priority 2 for me)
Do not need this channel 60 W NEW
Do not need this channel 27 -1 WUNI
Do not need this channel 48-1 Daystar
Do not need PROVODENCE chanels , only BOSTON
http://www.tvfool.com/?option=com_wr...cc4945387a4908 01826 15ft map
I would much prefer locating a new antenna pointing south from a location 15 ft. above the ground on my front porch roof with about a fifty foot run of coax.. I want to avoid going up on my main roof to the chimney, that would be about a 100 ft. run and I do not like going up on the steep roof.
I want to setup a new second TV. (I have not yet purchased the new second TV so cannot give you a model number) The second TV will be close, less than 20ft. from the porch antenna location.
Cost is not a major object but if I can get away without the complication of an amplifier that would be nice.
I have been told that I should probablyy use a 4-bay antennas: such as
Antennacraft U-4000
Antennas Direct DB4e
Channel Master CM-4221
Winegard HD-4400
I plan on initaly installing at 15 ft. then going up to the 30 ft chiminy if I need to.
Any recommendations appreciated. Thank you
NascarNHIS is offline   Reply With Quote
