The only Fox channel within your reach is real 34 at 82 degrees.
To receive this and the other stations to your NW you need a rotor and amplifier. If you use the Pro Brand Eagle Aspen Roto100 and replace the U/V combinder with a Winegard AP2870 amplifier, you will be able to accomplish this without the installation of a second cable for the rotor.
The Roto100 uses the coax to operate, provided you follow exactly the manufacture instructions for single cable installation.
