That Didn't Work
Okay then... I've had a lot of time to think about what has been suggested here.
I am now thinking a little differently on what I should be ready for.
I would like the unit for set to be a useful item for a digital tv. Is this meaning I'd need to consider DVR? If so, is there one that has good reviews? Will it work on my analog tv? From what I've read, I think it should but look to your voices to confirm.
I also would like to start with an indoor attic antenna which would simply be the easiest to install. I'd like it to also work on digital TVs. The 7000R has been mentioned as a great unit but I wonder if I decide to eliminate cable boxes what impact hooking an antenna to more than one tv could be? How many antennas could I possibly need? If I decide I get enough tv with the analog I'll assume the same could be expected of digital tvs? I probably won't need set-top boxes for the digital tvs but ask that with my new consideration of the task of which I'm about ready to pull the trigger on which are solidly reccomended boxes (DVR type) and attic antennas and for multiple tvs is more than one antenna advised?
Thanks,
CJ
