Old 14-Nov-2012, 8:45 PM   #10
When coax is cut and the end of the coax is 'dressed' cut so the connector can be installed on the coax.
The foil and shied wires can be pushed in toward the center conductor to the the point that the foil and shield wires are touching or wrapped around the center conductor.
Look inside the connectors on the ends of the coax.
If water get's in the coax , put the coax in the trash.
Disconnect the coax from the antenna , does the light get brighter now??
Disconnect the coax from the preamp , does the light get brighter now??
Disconnect the antenna coax from the power injector , does the light get brighter now??
Disconnect the other coax from the from the power injector , does the light get brighter now.
