Old 14-Nov-2012, 6:11 AM   #3
There are No Magic Tv Antennas.
Many question askers come here looking for advice to get better reception when they too find out that mohu leaf Is Not a magic Tv antenna.
Your best reception with a indoor type antenna will be with a Terk HDTVi (not the HDTVa) indoor antenna , at/in a window that is toward the , north east.
Aim the HDTVi antenna at about 35 degree magnetic compass. Here is how to aim indoor type antennas , http://www.kyes.com/antenna/pointing/pointing.html.
___________________________________________________________
When your are ready to go for reliable and stable reception.
I recommend a Winegard HD7082P antenna above the roof , installed in such a manner that the roof or house is not blocking reception to the , north east.
(I recommend the HD7082P antenna , it has better antenna gain - reception ability - on the VHF low band channels of 2 thru 6 where your reception situation requires more reception ability)
Aim the HD7082P antenna at about 35 degree magnetic compass direction.
Here is how to aim outdoor type antennas , http://www.kyes.com/antenna/pointing/pointing.html.
No preamplifier is required.
As always trees and tree leaves do a real fine job of reducing or blocking Tv transmissions and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
