Old 14-Nov-2012, 3:57 AM   #2
The digital broadcast tv transmissions are Very Strong Signal Strength at your location.
_______________________________________________
ALL coax and connectors and hardware is Suspect of of being bad. As in ALL coax.
That coax and connectors that goes to the Plasma Tv in the basement is suspect of being bad.
As a Test , run a new coax and connectors down the stairs to the tv in the basement.
Also , DO NOT chain splitters one after the other , DO NOT connect one splitter to another splitter to another splitter to another splitter to another splitter.
Each time a splitter split takes place the signal strength is reduced so at the end of a chain of splitters , not much signal remains.
The correct way is to use a splitter that has the number of outputs that go to each Tv location.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
___________________________________________________
The digital broadcast tv transmissions are Strong Signal Strength at your location.
And because the digital broadcast tv transmissions are strong at your location.
I recommend Remove the amplifier , and use the correct splitter that has the correct number of outputs to the Tv's that are connected.
____________________________________________________
Remember , ALL coax and connectors and hardware is Suspect of being bad.
Even the coax that is connected to the antenna.
I recommend aim the DB4 antenna at about 10 degree magnetic compass direction , ( an in between aim direction ) so as to receive WPXM-DT ION Television and the main group of digital tv stations to the , north east.
As always , the starting aim direction is the --> starting aim direction.
The antenna can be adjusted turned to the left and right to find a aim that has the best reception.
_____________________________________________________________
Digital Tv tuners can develop , Digital Glitchs , that are not cleared out with a simple channel rescan.
I recommend a Double Rescan of Tv.
http://www.dtv.gov/rescan.html
