Old 14-Nov-2012, 2:34 AM   #8
elmo
Originally Posted by nightshark View Post
Will either of these options work in the attic? I would rather not mount outside unless absolutely necessary.
The winegard must have a better range than the DB4e ?
Attics are ok, but not like being in the clear. Signals will get cut in strength and they'll bounce around some in the attic. It's like your cell phone; works great out in the open but at the back corner of the grocery store, it cuts out on you. But you can always try it out and if it doesn't work, then move it out and up.
