Are there trees, shrubs or buildings in the way of your antennas' view to the south?
How long is the cable from your antenna to the TV?
How many TVs are connected?
Is the cable and splitter new?
Have you tried adjusting the aim?
I would be very reluctant to 'throw' an amplifier at this problem. The information provided in your TV Fool report indicates that you are quite close to the transmitters and that the signal levels are quite strong. It's possible that the signal from the transmitting antenna is not directed downward as much as predicted. If that's the case, a larger antenna may be needed but let's exhaust the other possibilities first.
