Old 13-Nov-2012, 6:12 PM   #4
Colorado Springs TV Fool
Thanks but we're still struggling....
So, we did exactly what you advised: got the RCA ANT751r, got a specialist to install it on our roof, point it to 166 degrees, and connect it to 3 tv points. But when we did out channel search, we're still not getting CBS (49), NBC (5.1) or FOX (21.1).
His suggestion is that we may be too close to the broadcast point. (We can see it atop Cheyenne Mountain, about a mile or two from our house.) He said that because of our close location, the signal may be bouncing over our house. His only idea was that an amplified antenna may work to capture those channels.
Any ideas on what might be happening? Would an amplified antenna solve our problem? If so, is there one you can recommend? We can mount it on our roof....
Thanks!
Colorado Springs TV Fool is offline   Reply With Quote
