I would also recommend an outdoor antenna.
True, you do have some VHF channels, but which ones can you do without?
I receive many of those same channels and the only things that aren't usually duplicated, are the local news, PBS and IND channels.
I am also receiving WLS w/ a UHF only antenna at 47 miles, even though my signal diagnostics say it is broadcasting in VHF high, so you may not need much of an antenna, for that.
