Thread: Antenna help
Old 13-Nov-2012, 5:20 AM   #3
The ANT751 will limit the reception at your location.
The ANT751 is designed to receive channels 7 thru 51.
The ANT751 is a small antenna.
And if you put it in the attic your channels received will be reduced.
If the attic has metal backed insulation , or a metal roof , or solar panels , or the roof has concrete or adobe roof tiles or the the ANT751 is aimed through brick on the outside of the house that reaches up as high as the attic , reception will be reduced more.
_____________________________________________________
Your location has Digital Tv stations/channels in all 3 Tv channel bands of ,
UHF band channels 14 thru 51.
WOCK-CD is transmitting on Digital channel 4 , http://en.wikipedia.org/wiki/WOCK-CD , http://americaone.com.
For Digital Tv reception of the Current Plus Pending Applications Included Digital Tv Stations to the east in the tvfool channel list down to and including WOCK-CD.
I recommend a Tv antenna that is designed to receive All 3 Tv channel bands.
Install a Winegard HD7082P antenna with no preamp above the roof aimed at about 90 degree magnetic compass direction , east.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 TV's connected use a common simple 4 way splitter.
WOCK is a weak signal and every time a split takes place the signal is reduced in signal strength so if WOCK is not received well with 3 or 4 Tv's connected then install a Channel Master CM3410 distribution amplifier ahead of the 3 or 4 way splitter.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the HD7082P at a location that has the least amount to no amount of obstructions in the direction of reception.
