Old 11-Nov-2012, 3:38 PM   #5
Install a Antennas Direct DB4e UHF Antenna aimed at about 185 degree magnetic compass direction.
The DB4e is recommended because it has a Wide forward reception pattern , the Tv stations are Widely spaced , south west , south , south east.
The DB4e is not recommended because it is small.
During this time period on this planet , small is a key word , small , smaller , and then so small you can't see it.
Install a Winegard YA1713 VHF antenna aimed at about 166 degree magnetic compass direction. The YA1713 is VHF high band channels 7 thru 13 antenna for reception of WBBZ.
____________________________________________________________________________
Use a UVSJ = UHF/VHF Separator/Joiner to connect the 2 antennas together to 1 coax.
Type these letters in the Google search box -> uvsj . Type these letters in the http://www.solidsignal.com , in search box -> uvsj .
For 2 Tv's connected use a common simple 2 way splitter.
Some roof top antenna mounts are , tripod antenna mounts , eave antenna mounts , chimney antenna mounts.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.antennasdirect.com , http://www.winegarddirect.com , http://www.solidsignal.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best install the antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
