Old 10-Nov-2012, 4:44 AM   #4
The CS2 antenna is a UHF channels 14 thru 51 antenna.
Your location also has VHF high band channels 7 thru 13.
Install the VHF antenna kit on to the CS2.
http://www.antennasdirect.com , has the VHF antenna kit.
Aim the CS2 with the VHF antenna kit installed.
At about 330 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes,com/antenna/pointing/pointing.html.
The Digital Broadcast Tv stations/channels , are Strong Signal Strength at your location.
Here is a list of the receivable Digital Broadcast Tv stations/channels at your location.
KTWU REAL VHF channel 11 , virtual number (11.1-2-3) PBS.
KSNT REAL UHF channel 27 , virtual number (27.1-2) NBC and FOX.
http://en.wikipedia.org/wiki/KSNT
KSQA REAL VHF channel 12 , virtual number (22.1) The Country Network.
KTMJ-CD REAL UHF channel 43 , virtual number (43.1) FOX.
http://en.wikipedia.org/wiki/KTMJ-CD
K40IJ-D REAL UHF channel 40 , virtual number (x) EICB Religion.
WIBW-TV REAL VHF channel 13 , virtual number (13.1-2-3) CBS and MyNetwork and Me-Tv.
KTKA-DT REAL UHF channel 49 , virtual number (49.1-2) ABC and The CW.
WIBW-TV REAL UHF channel 44 , virtual number (13.1-2-3) CBS and MyNetwork and Me-Tv.
___________________________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the antenna at a location that has little obstructions to no obstructions of any type or kind in the directions of reception including your own house.
At your location that is , west , north west , north east.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Remove All Dish Network connection hardware such as , diplexers , splitters , power supplies , power injectors , and etc..
Have only 1 Tv location connection to the antenna , do not use any splitters.
Now Rescan for Digital Broadcast Tv Channels.
Digital tuners can develop 'digital glitches' that are not cleared out with a simple channel rescan.
Do a Double Rescan.
What is reception like Now??
---> Important Question <---> how many Tv's are connected??
