The ANT-751 would be a much better choice because it is designed to receive UHF and High-VHF signals. The Leaf is a UHF only design.
WJW, WOIO & WCDN are broadcast on High-VHF channels.
Outdoor mounting is also going to help as well.
Try this with a passive 3-way splitter, no amplifier. Most 3-way splitters have a -4 dB port and two -8 dB ports, use the -4 dB port to feed the longest cable run.
Reason: Simplify
