Many Thanks For The Info. !
Say, you've rattled off the info. I need seemingly effortlessly and I honestly appreciate your time. The only reason I mentioned the FIOS was that when I had it, they installed a panel that has all the home runs attached right there at one split location. I was going to run the new cable line from the antenna down to that point for simple reconnection. You've provided me with all info. and the point where I got stuck a lot where you referenced stand still was looking at user reviews of boxes and you've mentioned the 7000R so I'm good there. I can get a converter box for the old analog TV like you say but is there a specific one (you mentioned the RCA DTA800B1. This one you would use for the analog TV. Which ones might toy use for a digital TV. If I test one out, and based on your advice, I only want to buy one as a test unit and see how it goes but if I like it, I'd prefer to not wish I had purchased the "other" unit. Any reccomendations on any boxes for digital TV based on this description? I won't be spending more than a 150.00 or so I guess. I'd like to also plan for a unit that might record and actually seems to get some of the cable channels if possible.
What are my limitations on channels please and could you name a couple units that are the better units?
Thanks very much !
Chris
