Install the VHF up-grade kit for your CS2, available from Antennas Direct.
Play with an aim just between your two groups of stations located West and Northwest. If a station in either group fails to play reliably, move a little toward that station. If you can't find a sweet spot for all stations, you will need a rotor.
Even with the rotor you will be within your budget.
