Old 13-Oct-2010, 11:57 PM   #5
jjevans
Above is the FM Fool report. Looks like the actual transmitter has moved from their original headquarters. A couple stations at 50KW around 10 miles away in the higher frequencies and a couple at under 5KW around 6 miles away in the low 90's. Maybe I don't need the trap? Also, one response said overboosting wouldn't be a problem. Does that mean I could preamp both UHF and VHF in the 20db - 30db range? Thanks for the quick advice so far. It is really appreciated.
jjevans is offline   Reply With Quote
