Hang a pipe down from the roof beam to mount the antenna , can even use a plastic pipe , however do not use a Tiny little diameter plastic pipe.
It is usually best to get the antenna up in the attic , not having the antenna on the floor of the attic.
It is best to keep the antenna away from HVAC and ducting in a attic.
