25 feet antenna height is a reference point height.
The signals are strong at your location , 15 feet or so will be fine for antenna height.
_________________________________
Coax cable connectors and the coax connectors used with Tv antenna systems are the same. Coax with connectors on the ends will be Ok for connection hookup.
The coax connectors are the same for digital or analog.
_____________________________________________________
The HD7000R is the best antenna for your location because your location has Tv channels in All three Tv bands of ,
UHF band channels 14 thru 51.
The HD7000R is a All band antenna that is not all that directional and that is what is required at your location , a antenna that is not too directional so as to receive the Tv transmissions from other directions around the compass.
There is No Such antenna as a digital tv antenna.
There is No such antenna as a HD antenna.
A antenna will Receive Both digital and analog.
A HD7000R that is labeled for digital HD reception is the Same as a HD7000R that is not labeled for digital HD reception.
And the Same is true for other antennas.
HD Digital Antennas were invented in markting departs as a way to sell more antennas.
People respond to 'Key Words'.
So markting departments use 'Key Words' so you will buy.
I provided some Digital to Analog converter boxes to use with older Analog Tv's that you might have or any Tv's that do not have a Digital Broadcast Tv Tuner.
Or perhaps you would like a box that does more the the basic functions of changing channels and controlling volume , your choices.
Any questions that you have are Ok.
However please note , it is possible to ask questions to the point that one comes to a standstill and also talk ones self into a stand still.
The best way is to get practical and useful information , as is happening here , and then Go For It.
You will not be using any of Fios system equipment or cable tv equipment with the antenna system.
Yes use the coax with connectors on the ends because the Tv antenna signals need to get from the antenna to the Tv's.
