Old 8-Nov-2012, 1:30 AM   #7
Here are Digital Tv stations/channels to the , north , north west , at your location.
The following are receivable at 25 feet antenna height.
WVIB-DT REAL UHF channel 39 , virtual number (4.1) CBS.
WGRZ-DT REAL UHF channel 33 , , virtual number (2.1-2) NBC and Antenna Tv.
WKBW-DT REAL UHF channel 38 , virtual number (7.1) ABC.
WNYO-TV REAL UHF channel 49 , virtual number (49.1) MyNetwork.
WUTV-DT REAL UHF channel 14 , virtual number (29.1-2) FOX and Country Net.
WNLO-DT REAL UHF channel 32 , virtual number (23.1) The CW , is very weak of signal strength at 25 feet antenna height and may or may not be received.
For reception of the Digital Tv stations/channels to the , north west , north , at 25 feet antenna height , install a Channel Master CM4228HD antenna and a Channel Master CM7778 preamp , aimed at about 345 degree magnetic compass direction.
Install the CM4228HD antenna about 3 feet or more above the metal roof in such a manner the the metal roof is not blocking reception to the , north , north west.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/Trapods%200703/4712.html , http://www.ronard.com/909911.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
_____________
It is best to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
