Old 7-Nov-2012, 2:10 AM   #3
tomcannondesign
splitter/amp
Thank you for the detailed reply.
I am leaning towards buying an RCA ANT751R Antenna to put into the attic. I don't like the idea of installing an antenna next to each TV. I have TV's in areas that I could not do that. Having 1 large antenna in a high area 25ft above ground level seems to be better than 6 small antennas with each TV.
This is the antenna I may buy from Amazon:
http://www.amazon.com/RCA-ANT751R-Ou...eywords=ANT751
I will have 5 TV's in the house. What splitter/amp do you recommend?
Thanks for your help.
tomcannondesign is offline   Reply With Quote
