Old 13-Oct-2010, 9:44 PM   #3
Tower Guy
Originally Posted by atticus5176 View Post
Could someone tell me which antenna I need, and whether a pre-amp is also necessary?
option 1.
Winegard HD7694P with AP 8700 preamp.
option 2.
Winegard HD7698P might work OK without a preamp.
option 3.
Antennacraft Y10-7-13 for VHF with an 8 bay UHF antenna or a 91XG yagi style antenna. Use a AP 2870 preamp to add them together.
Seal things well at the connection points. Consider using Krylon spray to keep the salt off of the antenna.
You could try the AP 8700 preamp with your existing antenna, but I'd guess that you'd find corrosion in the F-connectors when you install it.
