Old 6-Nov-2012, 4:24 PM   #2
As always , Attics Are Not a reception friendly environment and Never Will be a reception friendly environment.
For Improved Reliable Reception move the antenna to Above The Roof.
No antenna amplifier.
Install the antenna above the roof in such a manner that roof or house is not blocking reception to the , south west , south , south east , north west , north , north east.
Here is the Federal Antenna Law that says Yes You Can , install , use , maintain , antennas above the roof , http://www.fcc.gov/mb/facts/otard.html.
Aim the antenna at about 190 degree magnetic compass direction , an in between aim direction of the Tv stations to the , south west , south , south east.
Here are some Above The Roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions including your own house in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
