Thread: New OTA Setup
Old 6-Nov-2012, 6:36 AM   #2
If your tvfool radar report plot is correct with the correct address then in the Current Plus Pending Applications Included Digital channels list is a Looong list of LOS = Line Of Sight , Digital Tv stations that are in the Green and Yellow reception zones.
The Tv transmissions Are Very Strong Signal Strength at your location.
Install a ANT751 antenna above the roof in such a manner that the roof or the house is not blocking reception to the north west group of Tv transmitters.
Aim the ANT751 antenna at about 323 degree magnetic compass direction , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
http://www.solidsignal.com , has the ANT751 antenna with a J type antenna mount for , low dollars.
Check http://www.amazon.com , also.
The Tv transmissions Are Very Strong Signal Strength at your location , No antenna amplifier is required and is contraindicated due to the strong signal strengths.
For one Tv connected use No splitter.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
________
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
