Old 13-Oct-2010, 8:26 PM   #1
atticus5176
Newbie needs antenna advice
I am on the Outer Banks of NC and get most channels from the Norfolk area. I have a mid-range antenna mounted outside, and have been losing channels. It appears I need a large directional antenna. My survey result is here:
http://www.tvfool.com/?option=com_wr...a36254b26bf9d2
The channel I have lost that is most important is in yellow - the ABC affiliate.
Could someone tell me which antenna I need, and whether a pre-amp is also necessary? I think I need something with both UHF and VHF capacity, but am unclear on what to look for. The channels I do get are excellent. I have no idea why I have lost the ABC affiliate - which used to come in fine.
My antenna would be mounted outside on the north side of the cottage; about 15 feet off of the ground.
Thanks!
Bob
atticus5176 is offline   Reply With Quote
