so a little disappointment today
i aimed the Y10713 at 159 magnetic
db 8 is still pointed at approx 135
joined the db8 and with a uvsj (CHANNEL PLUS 2512 DC + IR Passing 2-Way Splitter/Combiner)
the out of the usvj is connected to the in on the cpa-19
the to tv of the cpa 19 is rg6 all the way down to a wall plate splitter so it looks like this
UHF Antenna
UVSJ -->cpa-19-------wall plate--Power Supply Inside--> TV
VHF Antenna
All that said i did a scan and I only get 1-2 channels....where as with the db8 only i was getting 8-12 channels. So my troubleshooting will be to remove the amp and do another scan. Any other thoughts or suggestions?
