Old 4-Nov-2012, 11:42 PM   #4
mcarland
Excellent questions. I should have thought of hooking straight up to the antenna. It did cross my mind, but I forgot I had a small Vizio I could bring up instead of running a long line to my wall mounted TV. I used the short leads that currently connect the antenna to the preamp.
One of the splices is to go through a panel, and the other is a wall faceplate. I could probably work around the faceplate one, but there's no way I'm getting another run down from that attic. On that note, it was a real bear getting that antenna installed up there, only 2.5' to work in, blown insulation, the stuff of my nightmares. I think I could work something out with the wiring if I had a solution to what I found below with just the antennas.
The test results closely mirror my anecdotal report. I think I had been getting a few lower channels through the FM antenna before I removed it. I'll put the grid in a code block so it stays in correct columns. The Vizio would report signal strength as a series of up to 8 dots, I listed the number of reported dots for each of the antennas:
Code:
RF	Chan	UHF	VHF
11	11.1	X	4
9	9.1	6	X
40	41.1	2	X
45	5.2	7	7
35	5.1	7	7
34	2.1	2	4
23	2.3	6	5.5
32	4.1	6	7
29	29.1	7	7
22	23.1	7	7
43	43.1	2	3
Channels AntennaWeb says I should get but don't care about
16	16.1	6	3
25	25.1	1	X
Other channels I found
	62.1	3	2
	33.1	3
	48.1	1
	50.1	1	1(blocky)
If the VHF could pick up RF9, I think I would be in good shape. It seems odd to me that the UHF can pick it up so well, and RF34 as well.
mcarland is offline   Reply With Quote
