Old 4-Nov-2012, 9:37 PM   #3
As always , Attics Are Not a reception friendly environment and never will be a reception friendly environment.
A Tangle of a installation.
This antenna that antenna and some other antenna , this splitter that splitter and some other splitter , and the preamplifier is connected to Tangle somehow.
-->It is Time to Simplify !! <--
Install the CM3016 Above the Roof in such a manner that the roof and the house is not blocking reception to the north.
Do not use the preamplifier.
Do not use any of the power supplies , power injectors or ect.
Disconnect and remove the preamplifier , power supply and power injector.
Disconnect and remove every part and piece that is not required to make Simple antenna system.
Do Not chain splitters , one splitter connected to another splitter connected to another splitter connected to another splitter , each time a split takes place the signal strength is reduced , so at the end of the chain of splitters there will be little to no signal.
The following is the correct way to connect splitters.
For 3 Tv's connected use a simple common 3 way splitter.
Aim the CM3016 North , Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Here are some above the Roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at sollidsignal by typing the word ronard in the solidsignal search box. http://www.solidsignal.com.
As always , trees and tree leaves do a real fine job of reducing or blocking reception and so do , buildings , hills , mountains , and other obstructions.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometime named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
