Old 3-Nov-2012, 5:36 PM   #18
Stereocraig
Originally Posted by Name141 View Post
OK, so uh.. what's a "drain loop" . Also, since I don't want to pick up FM stations, I would want to set the FM Trap to "Fixed Trap In" ?
Wherever the coax connects, make sure you run it down past that point and then back up to the connection, or the opening in the building. I have always called it a drip loop, but maybe that's just a loose translation.
Look around at how other people's satellite and cable wires are on the outside where the service drop is.
Yes, FM trap in.
