If the chase is a wood chase like inside walls and etc. , can make access doors at problem locations.
Steal fish tape is a way to go along through a chase , keep wiggling and working the fish tape through.
HVAC ducting is a way to get coax and communications wiring from point A to point B.
Also can drill one floor to next floor in , closets , pantries , and etc.
I have used a high output leaf blower to blow a styrofoam ball with a string through a chase.
Connect the leaf blower output to the chase with , card board / duct tape / ect.
Make hole in the card board or duct tape , etc. so can feed string in and pull back on the string if required until the styrofoam ball and string goes through the chase.
